Limitations in DHCP pools on ASA5500
Oct 7th, 2009
Apparantly ASA5500 has a limitation on 256 IP-adresses in a dhcp pool ??!!!
Why and is there a workaround/ hidden command to disable this limitation, which seems rather arbitrary ? Thanks. /JJ
Collin Clark Thu, 10/08/2009 - 05:43
I don't know of any commands to alleviate this, there probably aren't any. I would assume the limitation is due to the fact that general LAN design suggests no more than 254 hosts per IP segment.
sokakkar Fri, 10/09/2009 - 12:59
The size of the pool is limited to 32 addresses with a 10-user license and 128 addresses with a 50-user license on the Cisco ASA 5505. The unlimited user license on the Cisco ASA 5505 and all other security appliance platforms support 256 addresses.
