Tips for DME - WM Server Streaming Configuration
Oct 8th, 2009
Hey pros,
Here i am again, seeking for your advice!
So,we have implemented the DMS and we have reached the point were we need to configure the DME and WM Server.
As far as i can understand, the relation between the later should be :
DME:push configuration and the WMS to announce to a publishing point the stream.
So, the tips i'm asking for lay over here:
On the DME,while configuring the Push configuration, i'am asked to input the following:
Description,name,format: ok
Streaming server URL(inc port): http://<server's ip-OK>: <port> --> is it referring the the mms ports on the WMS?
Name of Publishing point: ok.
So actually the issue begins while starting the DME in push configuration mode.It starts for 2-3 seconds and then stops.So i suspect that it is related with the "Streaming server url" settings.
What do you suggest?
