ASA Stateful Failover
Answered Question
Overall Rating: 5 (1 ratings)
marioderosa2008 Thu, 10/08/2009 - 02:45
Thanks for the reply,
so if the ASA's have version 7.x or above, you can configure them as you would with 2 PIX's?
with a serial cable as the failover interface?
I breifly drafted through and probably not taking it all in properly.
Thanks again!
Mario
marioderosa2008 Thu, 10/08/2009 - 03:58
Ooops, forgot to ask... are there any special software/license requirements. Or would this be possible out of the box?
marioderosa2008 Thu, 10/08/2009 - 05:00
Hi Andrew,
thanks very much for the info.
Do you know what the below quote means from the article? not too familiar with different contexts.
Note: VPN failover is not supported on units that run in multiple context mode as VPN is not supported in multiple context. VPN failover is available only for Active/Standby Failover configurations in single context configurations.
Thanks!
marioderosa2008 Thu, 10/08/2009 - 05:57
lol, OK fair enough...
I am going to start comparing the 2 models... 5505's and 5510's.
Thanks for your help so far.
marioderosa2008 Thu, 10/08/2009 - 07:14
ok, now i'm confused...
so the 5505 & 5510 units do not apply to the URL that you posted right at the beggining of this conversation, no?
in general terms, for stateful failover, we need to be looking at 5520??
Mario
