10-08-2009 01:22 AM - edited 03-04-2019 06:17 AM
Hi All,
I had a question regarding 6509 chassis where we had installed two supervisor in slot 5 & 6.
SUP720-#B is installed in both slots with MSFC3 & PFC3 installed on both SUP.
Both SUPs have same IOS version. But PFC & MSFC have different HW versions.In this case, will redundancy work?
Pls. suggest.
regds,
aman
10-08-2009 01:36 AM
AFAIK yes redundancy will work. RPR & SSO redundancy modes are not denpendant on HW versions of code, only IOS.
HTH>
10-08-2009 01:43 AM
Hi Andrew,
Thanks for info.
Can u share any cisco doc on the same?
regds,
aman
10-08-2009 01:54 AM
Sadly I do not have any docs on this - all my experiance has been hands on.
I have run 6500's & 7300/7600 routers on differenet module HW code and IOS versions.
If you are not 100% - open a TAC case.
HTH>
