Error with incoming and outgoing calls.
Oct 8th, 2009
I am having CCM 7.x and 3845 gateway router. I am running H.323 on gateway router.
however the calls are not getting mature. attached is the error for incoming and outgoing calls both.
Service provider is forwarding only last 3 digits and i am prefixing a "6" to this incoming digits under H.323 gateway configuration.
But the calls are working fine with MGCP.
thanks
KonradStepniewski Thu, 10/08/2009 - 06:14
Look like it's L1 problem: Cause i = 0x80AC18 - Requested circuit/channel not available
Do you have configured?:
voice service voip
Check: show isdn service and debug cch323 for more information.
