CCM Subscriber node problem when switch version 5.1.3-8
Oct 8th, 2009
I had the problem with the Bios of my x306m on a Publisher / Subscriber with Call manager at 5.1.3-4000-4. bug (FN#63255 ) Need to upgrade bios and CCM
So I basicly had to upgrade Publisher and subscriber to 5.1.3-8
I did the procedure on the web site but ( publisher = fine at 5.1.3-8, subscriber = not fine )
If boot on ( new & old bios ) = boot process stop on " Activating swap partitions "
If boot on 5.1.3-4000-4 CD = stop on.. ( * bad because I can't not even re-install back the 5.1.3-4000-4 and switch the Pub at 5.1.3-4000-4 + upgrade again )
Lofical drive information
Lofical drive number 1
Logical drive name : Drive 1
Status of lofical drive : Okay
Raid level : 1
Number of chunks : 2
Drive(s) ( Channel,Device) : 0,1 0,3
Command complete successfully.
7825I2-2800 machine's SATA RAID configuration complete
If I boot with the 5.1.3 recovery CD I have no menu but I can do Alt+F2. I did type dmsg and saw :
Mounting unchecked fs, running e2fsck is recommended
Warning (device sd(8,3)) : ext2_read_super : mounting ext3 filesystems ext2
Attempt to access beyond end of device
Rw=0, want=2, limit=1
Unable to read super block
Wrong magic
Bogus locical sector size 0
Bogus locaical sector size 0
Can't find a valid fat filesystem on dev 08 :05
Can't find ext3 filesystem on dev sd(8,5)
SO I did try to do that :
umount /mnt/part[1-6]
couldn't umount /mnt/part2: invalid argument
*but all other partion are unmount, except /dev/dev2
fsck.ext2 -y /dev/dev1
/:clean, 73019/1566720 files, 2850939/3128650 blocks
fsck.ext2 -y /dev/dev2
did'nt do it, because not unmount
fsck.ext2 -y /dev/dev3
/grub: clean 28/66528 files, 16822/265072 blocks
fsck.ext2 -y /dev/dev4
fsck.ext2 : attempt to read block from filesystem resulted in short read while ying to open /dev/dev4
fsck.ext2 -y /dev/dev5
couldnt find ext2 superblock
fsck.ext2 bad magic number in super-block
fsck.ext2 -y /dev/dev6
/common: clean, 8407,6340608 files, 1752904/12661220 blocks
still same result when I boot...
any idea ??
