10-08-2009 06:14 AM - edited 03-15-2019 05:11 AM
We upgraded to 6.1 from 4.1, on 4.1 I was able to download one song to MOH audio source. I then applied it to Device Pools. That option is not available on 6.1.3. Do i have to add it to all the phones now?
Solved! Go to Solution.
10-08-2009 06:33 AM
No, configure it under the Common Device config
java
if this helps, please rate
10-08-2009 06:33 AM
java
