10-08-2009 06:40 AM - edited 03-15-2019 07:58 PM
I am replacing a fxo card on a 2811. Are thes cards hot swap?
Thx
10-08-2009 06:45 AM
No, you would need to power down the router.
Hope that helped, if so please rate.
10-08-2009 06:48 AM
10-08-2009 06:49 AM
Hi There,
Unfortunately No, You will need to shut down the router to install this module and go through the POST. (Power on self test)
Justin
