Cisco 877 ADSL2+ Annex A - What is Going On!"
Oct 8th, 2009
I understand why there are issues with Annex M deployements in UK, however I believe the Annex A should be compatable.
In every case teh router is either doesn't sync or is unstable and collapse after a certain period depenedent on the amount of data.
The problem is characterised by middle and big buffer failures. ICMP and SSH to the box are fine, but normal data traffic stops.
A reboot is the only option to clear the buffers
Here is example info:-
1 vote
Ian Cowley Thu, 10/08/2009 - 07:42
IFP-C877-ADSL#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 20-Jun-09 02:20 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
IFP-C877-ADSL uptime is 21 hours, 25 minutes
System restarted at 15:45:02 UTC Tue Oct 6 2009
System image file is "flash:c870-advipservicesk9-mz.124-24.T1.bin"
Ian Cowley Thu, 10/08/2009 - 07:43
Cisco 877W (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FCZ1113236K
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 802.11 Radio
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
IFP-C877-ADSL#sh dsl int a0
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM: 0x03 0x2
Chip Vendor ID: 'STMI' 'IFTN'
Chip Vendor Specific: 0x0000 0x71B9
Chip Vendor Country: 0x0F 0xB5
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x0000 0x0000
Modem Vendor Country: 0xB5 0x00
Serial Number Near: FCZ1113236K
Serial Number Far:
Modem VerChip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Capacity Used: 52% 99%
Noise Margin: 10.0 dB 6.0 dB
Output Power: 20.5 dBm 12.0 dBm
Attenuation: 30.5 dB 14.0 dB
FEC ES Errors: 51 2
ES Errors: 8 1
SES Errors: 8 0
LOSES Errors: 8 0
UES Errors: 0 86
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xE7
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 21767 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_3.0.33_nobist.bin
Operation FW: AMR-3.0.033.bin
FW Source: external
FW Version: 3.0.33
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 9728 0 1194
Cells: 0 24577129 0 174136395
Reed-Solomon EC: 0 1564 0 350
CRC Errors: 0 5 0 32
Header Errors: 0 3 0 30
Total BER: 0E-0 4804E-13
Leakage Average BER: 0E-0 7728E-19
Interleave Delay: 0 17 0 11
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
LOM Monitoring : Disabled
IFP-C877-ADSL#sh int a0
ATM0 is up, line protocol is up
Hardware is MPC ATMSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 1194 Kbit/sec, DLY 300 usec,
reliability 255/255, txload 28/255, rxload 151/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
10 maximum active VCs, 64 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 26
Queueing strategy: Per VC Queueing
5 minute input rate 708000 bits/sec, 146 packets/sec
5 minute output rate 135000 bits/sec, 130 packets/sec
3550095 packets input, 1252801794 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3427796 packets output, 462411711 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
Ian Cowley Thu, 10/08/2009 - 07:44
sh buffer
Buffer elements:
1027 in free list (1119 max allowed)
14311492 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 40, permanent 50, peak 56 @ 21:25:46):
38 in free list (20 min, 150 max allowed)
1143702 hits, 75 misses, 144 trims, 134 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 89, permanent 25, peak 89 @ 00:58:52):
82 in free list (10 min, 150 max allowed)
4330623 hits, 198 misses, 80 trims, 144 created
58 failures (0 no memory)
Big buffers, 1536 bytes (total 56, permanent 50, peak 79 @ 04:47:38):
40 in free list (5 min, 150 max allowed)
854620 hits, 93 misses, 119 trims, 125 created
12 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10):
10 in free list (0 min, 100 max allowed)
12 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
0 in free list (0 min, 10 max allowed)
0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 3, permanent 0, peak 3 @ 00:54:44):
3 in free list (0 min, 4 max allowed)
509 hits, 2 misses, 1 trims, 4 created
Interface buffer pools:
Raw Cell Private Pool buffers, 100 bytes (total 32, permanent 32):
0 in free list (0 min, 32 max allowed)
32 hits, 0 fallbacks
16 max cache size, 0 in cache
16 hits in cache, 16 misses in cache
Syslog ED Pool buffers, 600 bytes (total 132, permanent 132):
100 in free list (132 min, 132 max allowed)
5186 hits, 0 misses
Dot11Radio0Psp buffers, 1676 bytes (total 80, permanent 80):
80 in free list (0 min, 80 max allowed)
0 hits, 0 fallbacks
SEC Eng Packet buffers, 1700 bytes (total 256, permanent 256):
0 in free list (0 min, 256 max allowed)
256 hits, 0 fallbacks
256 max cache size, 256 in cache
0 hits in cache, 0 misses in cache
Dot11Radio0 buffers, 2400 bytes (total 96, permanent 96):
32 in free list (0 min, 96 max allowed)
64 hits, 0 fallbacks
Particle Clones:
1024 clones, 37144 hits, 0 misses
Ian Cowley Thu, 10/08/2009 - 07:45
This unit is running but will be expected to fail soon.
The ATM drops are at 86 8hrs after these traces.
miomalle Thu, 10/22/2009 - 05:11
Hi Ian,
Did you get anywhere with this? I am experiencing the same issues. Firmware 4.0.15 is a stable enough, but not perfect.
I tried the latest version 9, which made the problem worse!
I have changed the dsl noise-margin to 1.5 which has helped a little too (need to enable service internal for this command to be available).
The ISP we have is Demon, and they have said they have no end of problems with Cisco routers on their ADSL2+ lines.
miomalle Thu, 10/22/2009 - 05:25
Its on the 877-M.
Cisco TAC told me to use this version.
Ian Cowley Wed, 11/04/2009 - 04:42
No
I have been pushing this through major resellers and ISPs. No one seems to be interested.
I am using almost every feature on the router including an IPSEC VPN which may be contributing.
One ISP who uses these routers on private DSL/MPLS services has no issues at all.
I'll look into your noise margin settings too.
Other posts suggests 877-M thats applicable in UK to my knowledge.
miomalle Wed, 11/04/2009 - 04:49
Hi Ian,
Im having the same issues with no-one knowing the problem and wanting to help!
We are going to get a new line with a different ISP who uses the 877's regulary.
The link is still fairly stable with 4.0.15 and 1.5 noise margin - the only users who are affected are connected via VPN. If you are trying the noise marging, work from 3 down, with .5 decrements. I would also advise doing it while consoled in as sometimes the link can be virtually unusable.
Let me know if you get any answers, but next week we'll have the new line in.
Good luck!
chriswill Sun, 01/10/2010 - 14:14
   Did you guys ever resolve this issue. Got the same problem with a 877 dropping off dsl connection. Error logs show:
000086: *Jan  9 21:00:12.013 NZST: %LINK-3-UPDOWN: Interface Virtual-Access2, ch
anged state to down
000087: *Jan  9 21:00:12.013 NZST: %DIALER-6-UNBIND: Interface Vi2 unbound from
profile Di0
000088: *Jan  9 21:00:13.013 NZST: %LINEPROTO-5-UPDOWN: Line protocol on Interfa
ce Virtual-Access2, changed state to down
000089: *Jan  9 21:00:13.101 NZST: %LINK-3-UPDOWN: Interface ATM0, changed state
to down
000090: *Jan  9 21:00:14.101 NZST: %LINEPROTO-5-UPDOWN: Line protocol on Interfa
ce ATM0, changed state to down
Is this the same problem? and what are your margins now for noise if you found a better figure. I see from the output there are two figures.
Any help appreciated
Cheers
Chris
