Visual VoiceMail
Answered Question
Oct 8th, 2009
Running Unity 7.0(2) with both ES patches. CM is 7.1(3)
When I attempt to login to the Visual Voicemail I get an error saying my account is locked. In Unity both check boxes for locking accounts are not checked.
I have ran the premissions wizard with no luck. Any ideas?
Correct Answer by Christopher McAlpin about 7 years 6 months ago
You could be running in to the following defect:
Visual Voicemail reports account locked when it's not
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsz61924
Symptom:
When trying to log into Visual Voicemail to access Unity voice messages, the following message is returned: "Your account is locked. Contact your administrator to unlock your account." In this situation, the Unity subscriber account can be accessed by calling in from the phone, so it is not really locked.
Condition:
This problem may be seen using Visual Voicemail to access messages on a Unity 7.0(2) server, when there is no account lockout policy configured on Unity.
Workaround:
Go to the SA -> Account Policy -> Phone Lockout Policies
Select "Account lockout", select "Minutes" and set "Minutes" to a number between 1-100.
Wait after the lockout duration has ended.
Then retry logging in
Overall Rating: 0 (3 ratings)
imendezon Fri, 10/09/2009 - 14:49
Any luck with this? I am also running Unity 7.0(2) with CUCM 7.1.2 and can't get visual voicemail to work.
After inputing the userid and password the phone freezes up, so I don't even get an error.
jwells79 Wed, 10/14/2009 - 06:44
No luck yet. I try to login on the phone, I type in my password and I get as seen below in the attachment. My account is not locked in Unity.
jwells79 Tue, 10/20/2009 - 06:01
I am going to open a TAC case on this. I will post the results if i am able to
Correct Answer
Christopher McAlpin Tue, 10/20/2009 - 11:15
  • Cisco Employee,
Symptom:
Condition:
Workaround:
