10-08-2009 09:28 AM - edited 07-03-2021 06:08 PM
I have a couple of Cisco 1522 that I would like to setup on our Wireless Controller for a test. But I am running into some issues. I have a Cisco 4404 Controller running code 5.2.178.
I can get one of the Cisco 1522 to talk to the controller but i can't figure out how to get the other Cisco 1522 to talk to the Cisco 1522 wirelessly that is wired into the LAN. I have put both macs into the mac filter.
Here is the output from the bridge that is trying to hook up wirelessly to the bridge connected to the LAN
*Mar 1 00:14:25.675: %MESH-6-ADJ_VIDB_LINK: Mesh neighbor 0024.f7af.100f VIDB V
irtual-Dot11Radio0 dot1x control
*Mar 1 00:14:25.679: %LINK-3-UPDOWN: Interface Virtual-Dot11Radio0, changed sta
te to up
*Mar 1 00:14:26.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Do
t11Radio0, changed state to up
*Mar 1 00:14:40.675: %MESH-6-LWAPP_RESTART: Mesh Lwapp re-started
*Mar 1 00:14:40.675: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:14:40.679: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Mar 1 00:14:41.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
*Mar 1 00:14:47.883: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
esetinvalid level 0, slot 0, chan 11
*Mar 1 00:14:47.887: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:14:48.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
*Mar 1 00:14:51.483: %DOT11-6-FREQ_USED: Interface Dot11Radio1, frequency 4965
selected
*Mar 1 00:14:51.487: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:14:51.487: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar 1 00:14:51.491: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:14:52.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar 1 00:14:52.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
Mar 1 00:15:28.675: %MESH-4-NO_POTENTIAL_PARENT: There are no potential parent
s
*Mar 1 00:15:28.675: %MESH-4-NO_POTENTIAL_PARENT: There are no potential parent
s
*Mar 1 00:15:28.675: %MESH-6-LINK_UPDOWN: Mesh station 0024.f7af.100f link Down
*Mar 1 00:15:28.875: %MESH-6-ADJ_VIDB_LINK: Mesh neighbor 0024.f7af.100f VIDB V
irtual-Dot11Radio0 going down
*Mar 1 00:15:28.879: %LINK-3-UPDOWN: Interface Virtual-Dot11Radio0, changed sta
te to down
*Mar 1 00:15:29.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Do
t11Radio0, changed state to down
It looks like it connects up but then it gives that NO_potntial_parent error and disconnects. I really don't know anything about this and all i have done is take 2 out of the box and wire the one into the lan on the same vlan as the wireless controller and add it to the mac filter on the controller. Is there any other steps I am missing? I assume there is.
Thanks for any help.
10-08-2009 11:56 AM
Did you change the role of the 1520 that is wired into the network to be a RAP? The default setting is a MAP.
10-08-2009 11:59 AM
Yep i changed it to a RootAP under the Mesh tab on the controller. The wireless one still doesn't want to join the controller.
