IPCCX6.0(Prem)->7.0 Upgrade
Oct 8th, 2009
I have a setup of CUCM4.3 with IPCCX6.0
1.Has anybody done an upgrade from IPCCX6.0 to IPCCX7.0
2.I have been told it is not a straight upgrade and data/config is not ported over?
3.How to convert the licenses?
Overall Rating: 4 (2 ratings)
Jonathan Schulenberg Fri, 10/09/2009 - 08:36
  • Cisco Designated VIP,
    2017 IP Telephony
There is no upgrade path from 6.0. You will need to backup all data manually (scripts, repositories, subsystem configurations, license files, etc) and perform a fresh installation of 7.0. Everything will need to be manually restored. Scripts must be opened in the new editor and re-saved. UCM CTI Route Points, Ports, and Directory numbers must be deleted manually as CCX will not overwrite them when you configure the new jtapi subsystem.
atalante Fri, 10/09/2009 - 10:13
For licences if you have subscribed UCSS major upgrade, you can order for free an upgrade on upgrade tool site (put). If not, you have to order this upgrade.
Farid
