IPCC Express 5.0 ]**Parsing Fatal Error** Line 1 uri: null message: The en
Oct 8th, 2009
Hi all,
Last friday my IPCC stoped working again. We needed to reboot the server to make it work.
I'm working with:
VERSION INFO: Platform <2003 Service Pack 2>.
VERSION INFO: Debug threshold <OFF>.
VERSION INFO: Debug size <1048576>.
VERSION INFO: Debug files <2>.
VERSION INFO: Log size <1048576>.
VERSION INFO: Log files <2>.
VERSION INFO: TSSPAdm.exe: Product <Cisco Unified Contact Center Express 5.0> Version <6.4.2.12> Pri Build <5.0> Special Build < >.
VERSION INFO: LDAPClientDLL.dll: Product <Cisco Unified Contact Center Express 5.0> Version <6.4.2.12> Pri Build <5.0> Special Build < >.
I checked the logs of IPCC, and under:
cisco -> AlarmServiceLog
I found the AlarmTrace01.log, on this log I found this:
[2009-10-02 18:09:14]Initializing snmp service handler. Port = 65261
[2009-10-02 18:09:14]CiscoUtil.jar file found and AlarmService.properties file will be monitored.
[2009-10-02 18:09:33]**Parsing Fatal Error** Line 1 uri: null message: The entity name must immediately follow the '&' in the entity reference.
[2009-10-02 18:09:33]Error in parsing: Fatal error encountered
[2009-10-02 18:10:10]**Parsing Fatal Error** Line 1 uri: null message: The entity name must immediately follow the '&' in the entity reference.
[2009-10-02 18:10:10]Error in parsing: Fatal error encountered
This is the last thing we saw before the IPCC stoped working.
Then I checked the cisco-> desktop->log-> FCCServer001.log, and I found out this:
2009-10-02 18:10:10.832 INFO FCCS0000 fcCorbaServer: CORBA server started. Local server IOR is IOR:010000001200000049444c3a4643435365727665723a312e30000000010000000000000060000000010102000c00000031302e312e32312e3231360078e600000c0000004ac6885200000ea4000000010200000000000000080000000100000000545441010000001c00000001000000010001000100000001000105090101000100000009010100.
2009-10-02 18:10:10.832 INFO FCCS0000 updateLdapThread: Attempting to register this service in LDAP...
2009-10-02 18:10:21.925 INFO FCCS0000 updateLdapThread: Service registered in LDAP.
2009-10-02 18:10:21.925 INFO LC0059 LDAPConnectionMgr::EstablishConnection:: Connected to LDAP server on <10.1.21.216>.
2009-10-02 18:10:21.925 ERROR LRM_1000 CLrmTCPClientHandlerBase::LrmTCPClientRecvThread: ERROR: (17:socket connection closed by remote party)
2009-10-02 18:10:36.925 ERROR LRM_1000 CLrmTCPClientHandlerBase::LrmTCPClientRecvThread: ERROR: (17:socket connection closed by remote party)
2009-10-02 18:10:51.925 ERROR LRM_1000 CLrmTCPClientHandlerBase::LrmTCPClientRecvThread: ERROR: (17:socket connection closed by remote party)
2009-10-02 18:11:06.941 INFO FCCS0000 CChatServer::_setServerState: Service going into active mode. Incoming requests will be accepted.
The services stop working because of the parsing error, I had to reboot this server to start working again.
My big issue is that this had happened 3 times in the last month.
Do anyone knows why this parsing errros is appearing over and over again?
Or what do this error means?
Have a great day!!
Ramón Villavicencio
Abdulbaseer Mohammed Mon, 10/12/2009 - 07:41
  • Silver, 250 points or more
Are you using any type of webservices or making a data dip to get external info. Share this with those resources.
Sounds like you may have a mis match variable type what is expected vs what is provided.
None of this should be the cause of server crash I would check with cisco for latest upgrades etc for you what you have may be there is a known bug.
Good luck.
Baseer.
rvillavi Mon, 10/12/2009 - 10:04
Thanks a lot. I will look into that.
Ramón
