Courses Slides
Oct 8th, 2009
Hi All,
Is there a way to get the PPT slide show for a particular Cisco course, I was told earlier that I need a CCO login, but even with that I cannot find any, is there any body aware of this?
Richard Burts Sat, 10/10/2009 - 12:50
Osama
I am not clear from your post whether you are talking about regular Cisco certification classes (like BSCI or BCMSN) or some of the other courses (that might be delivered by a SE or other specialist). If it is the certification courses then the last time that I was involved with Cisco as a Training Partner the only way to get the PPT course slides was to be associated with a Certified Cisco Training Partner. I do not believe that this has changed. If it is other kinds of course then it might be possible - but I have never seen anything like it on CCO (and doubt that it is possible but I do not know for sure).
Rick
LordFlasheart Tue, 11/17/2009 - 01:02
Having attended a few Cisco courses the slides used by the instructors are the same as those in the Student Guides. I would be amazed if these were available to anyone with a CCO account. If applicable, ask around at work if somebody has a copy of the Student Guide you are after.
Please rate if helpful.
Good luck with everything.
swmorris Tue, 12/01/2009 - 23:54
They are only available to certified instructors of the particular course in question.  And there's a lot more DRM-type stuff in the current releases to prevent further dissemination beyond that group.
Scott
Internetwork Expert
