tunnel up but no ping from asa inside interface
Answered Question
Oct 8th, 2009
Dear All
i am establish a vpn tunnel between cisco asa 5510 and a cisco router.The tunnel is up and i can ping both crypto interfaces.Also from the asa console i can ping the lan interface of the router but from the router i can not ping the lan interface of the asa this message shows up in the log
%ASA-3-713042: IKE Initiator unable to find policy: Intf liaison_BLR, Src: 128.2
23.125.232, Dst: 129.223.123.234
Here is the config of the equipements.
I was able to successfully establish an ipsec tunnel with another 1841 ROUTER.I am having 1 hub site and 3 remotes sites with asa as hub.
Please Help.
Correct Answer by auraza about 7 years 8 months ago
Your crypto ACLs aren't matching. They need to be exact mirrors of each other.
Also, you may want to consider fixing the security-levels on the interfaces. They are all set to 0. Set the internal/private ones to a higher value.
Let me know how it goes.
PS. If you find this post helpful, please rate it.
Overall Rating: 5 (1 ratings)
Correct Answer
auraza Thu, 10/08/2009 - 13:46
  • Cisco Employee,
kolawole1 Fri, 10/09/2009 - 14:11
Thanks you i was able to solve the issue it was the matching of the access-lists.
Thanks big Boss
Thanks to the Netpro community.
rimbertr1 Mon, 10/12/2009 - 12:04
Make sure you are using the lan interface of your router to ping (by default the router will use the external interface - the crypto interface). Type ping with no other parameters and make sure to choose 'y' for extended commands to choose which interface to use to ping.
