Nokia E serious Phone integration with CCM 4.1.3
Oct 8th, 2009
I have one doubt, i can integrate nokial phones with CCM Version 4.1.3.
If its possible pls share some information about it.
virverma Thu, 10/08/2009 - 17:45
Not sure if it is possible for CCM 4.1 but it starts from cucm 6.X
Below is general configuration, I found, not sure if it is supported by cisco but if you want to test, you can check it,
On Call Manager
Under User Management ->End User, set the Digest Credential password for
a user that will use the SIP handset.
On the Phone configuration page, use the following parameter :
MAC Address :(MAC address of the SIP IP Phone)
Device Pool : (your device pool)
Phone button template : Third-Party SIP Device (Basic)
SIP Phone security profile : Non Secure SIP Profile auth by string
SIP Profile : Standard SIP Profile
Digest User : (same one as you set digest credentials)
On Nokia
Profile name: (you decide)
Service Profile: IETF
Default Access Point: (define the access point)
Public user name: @
Use Compression: No
Registration: Always On
Use Security: no
Proxy server settings
Proxy server address: sip:(your callmanager IP)
Realm: ccmsipline
User name:
Allow loose routing: Yes
Transport Type: UDP
Port: 5060
Registrar Server Settings
Registrar serv. addr.: sip: (your callmanager IP)
Realm: ccmsipline
User Name:
Transport Type: UDP
Port: 5060
Another option is to use Nokia Call Connect (NCC), using this you can
register your Nokia phone as a SCCP phone on CallManager. You can find
more information about this on the following links:
Please rate if this helps
