best way to remove CSM configuration from a switch
Oct 8th, 2009
have a redundant pair of CSM , would like to move slave CSM to a new switch, what is quickest way to eliminate all configuration from this switch so the same can be installed on the new switch , without reloading the switch or causing any downtime to already existing connections through the master CSM.
Martin Kyrc Fri, 10/16/2009 - 04:31
On new slave CSM you must configure only minimum parts for redundancy (link sent sachin). All other is synced automaticaly.
