Error on C3600
Oct 8th, 2009
I have a C3600 that has no config on it. When I power it up I get
C3600 processor with 65536 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
oC3600 processor with 65536 Kbytes of main memory
rommon 1 >
rommon 1 >
Can someone point me to a Document to figure this out?
jiaowenbin Fri, 10/09/2009 - 00:57
There are maybe serverl reasons cause your problem
1\ensure your flash disk (store ios) work well
2\ensure if boot command work well ,exmple :
rommon 1> dev ----list your what kind of media disks are in your router
rommon 2> dir flash: ------get your ios file name
rommon 3>boot c3660-xxx-xxx.bin
3\ if all above cannt boot your router,maybe flash disk has a hardware failure , change it
or , no ios file is in your flash disk,
if no ios file is in your flash disk ,
copy ios using tftp
copy ios using xmodem
copy ios using cf card adapter (u need to open the chassis ,find where flash disk locate)
send me e-mail for more help
[email protected] ,CCIE Security & SP
