Wlan Clients cannot see each other
Oct 8th, 2009
I have an 877w Dot11Radio interface with a pretty standard setup, the issue I'm having is the Wlan clients can't see/ping each other. They can all surf the net though. Do I need to allow mu to mu comms somehow?
interface Dot11Radio0
ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip nat enable
ip virtual-reassembly
encryption mode ciphers tkip
ssid 10
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0
station-role root
no cdp enable
dot11 ssid 10
authentication open
authentication key-management wpa
wpa-psk ascii 7 xxxxxxxxxxxxx
import all
domain-name xxxxxxxx
rob.huffman Fri, 10/09/2009 - 05:43
Hi Mathew,
On standard Autonomous AP's this is controlled via PSPF I'm not sure about the 877w but I thought it was worth a try;
Enabling and Disabling Public Secure Packet Forwarding
Public Secure Packet Forwarding (PSPF) prevents client devices associated to an access point from inadvertently sharing files or communicating with other client devices associated to the access point. It provides Internet access to client devices without providing other capabilities of a LAN. This feature is useful for public wireless networks like those installed in airports or on college campuses.
Note To prevent communication between clients associated to different access points, you must set up protected ports on the switch to which your access points are connected. See the "Configuring Protected Ports" section for instructions on setting up protected ports.
To enable and disable PSPF using CLI commands on your access point, you use bridge groups. You can find a detailed explanation of bridge groups and instructions for implementing them in this document:
•Cisco IOS Bridging and IBM Networking Configuration Guide, Release 12.2. Click this link to browse to the Configuring Transparent Bridging chapter: http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fibm_c/bcfpart1/bcftb.htm
You can also enable and disable PSPF using the web-browser interface. The PSPF setting is on the Radio Settings pages.
PSPF is disabled by default. Beginning in privileged EXEC mode, follow these steps to enable PSPF:
Command Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface dot11radio { 0 | 1 }
Enter interface configuration mode for the radio interface. The 2.4-GHz radio is radio 0, and the 5-GHz radio is radio 1.
Step 3
bridge-group group port-protected
Enable PSPF.
Step 4
Return to privileged EXEC mode.
Step 5
copy running-config startup-config
(Optional) Save your entries in the configuration file.
Use the no form of the command to disable PSPF.
Hope this helps!
MATHEW ATTWATER Sun, 10/11/2009 - 01:49
Thank you very much for your reply. It would seem all it took was to blow away my Dot11radio 0 interface and replce a very basic config (layer 3 on the dot 0 int).
All working fine.
