IP static routing
Oct 9th, 2009
hostname RTA
interface Loopback0
no ip address
interface Loopback1
no ip address
interface FastEthernet0/0
ip address 141.202.1.1 255.255.192.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
ip classless
ip route 141.202.0.0 255.255.192.0 Serial2/0
line con 0
line vty 0 4
login
end
hostname RTB
interface Loopback0
no ip address
interface Loopback1
no ip address
ip address 141.202.33.1 255.255.192.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
no cdp run
line con 0
line vty 0 4
login
end
hostname RTC
interface Loopback0
no ip address
ip address 141.202.17.1 255.255.192.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
no cdp run
line con 0
line vty 0 4
login
end
Richard Burts Fri, 10/09/2009 - 04:07
Max
You post some configs, but no question. What is the question you wish us to help you with?
Assuming that the question is about the validity of the configs I see at least 2 serious problems. The static routes point to interfaces that are shut down. If a static route points to an interface that is not up/up then the static route will not be put into the routing table.
Also your static routes point to serial interfaces. But the serial interfaces are configured with no ip address. If an interface is not configured with an IP address then it will NOT pass IP traffic.
Other than this, is there a question you want to ask?
Rick
stokesm3475 Sat, 10/10/2009 - 15:22
i'd thought that was suppose to do the trick, so instead of Fa0/0 i should go to Serial Interface 2/0. is that all i should do or is their something else.
