LMS 3.2 Ciscoworks assistant
Oct 9th, 2009
Trying to change the server settings - default credentials/policy configurations and keep getting this msg:
An active session for another user exists.
Do you wish to end the session and create a new session?
I click OK and login with Sys identity acct and it keeps showing the same window.
I rebooted server and it is still prompting me to keep logging in.
Thanks.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 10/09/2009 - 07:04
There may be a problem with the data in the opsxml database. You can try reinitializing this database to get CWA working again:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=opsxml dmprefix=Opsxml
