Cisco CME no Audio for Remote Phones
Oct 9th, 2009
We are having some remote users in our CME depolyment.THey are connected through VPN to the CME,we are able to register CIPC and when we dialed call is established but no audio in both phones.(when called between Remote to Remote user)
Central to remote and viceversa is working fine.
Overall Rating: 4 (2 ratings)
paolo bevilacqua Fri, 10/09/2009 - 06:21
  • Hall of Fame,
    Founding Member
Likely you don't have full IP connctivity between remotes, while you should.
Otherwise, try setting mtp under the corresponding ephone.
harisivaji Fri, 10/09/2009 - 06:39
Hey When i enabled MTP iam hearing One way audio.In another end they are not hearing anything.
paolo bevilacqua Fri, 10/09/2009 - 07:16
  • Hall of Fame,
    Founding Member
So fix you IP connectivity and you will be fine.
Please check what rating are you giving, because my answer above is 100% correct.
