Transcoding
Oct 9th, 2009
I configured transcoding using dsp resources on a 2800 series router and place the xcoder resource in a media resource group on callmanager7.
I then placed it into a MRGL for use.
With conference bridge resources I found out that I can use the resource from a non local router.
For example, I can place the mgrl that contains conference resources of the HQ router for use on the phone of a remote site.
However, I could not use remote xcoder resources to do transcoding on a local router.
Did I do something wrong or is this not suppose to work ?
Any help appreciated.
Paul
Hythim Ali El Hadad Fri, 10/09/2009 - 11:41
Hi paul,
yes you can use a conf bridge in a remote site but note that you will have the bandwidth of the 3-calls or more in your wan.
Also I think as you said transcoding could be used by the local ip phones only, remote phones couldn't use it
thanks
