ACS5.0 and WCS
Oct 9th, 2009
I'm trying to see if its possible to use ACS 5 patch 8 to authenticate WCS.
Looking at the ACS 5.0 gui I'm looking at where you would enter the tacacs+ or radius custom attributes. From doing some configuration it would seem that the tacacs+ custom attributes are not available but I found where you can enter the radius attributes but the cisco-av pair is a string filed that is one line and limited to 256 characters. Is anyone else trying to do this?
Lucien Avramov Sat, 10/10/2009 - 10:30
You can not integrate WCS with ACS 5.
WCS uses HTTP service for ACS, and ACS 5 does not support this.
You need to wait for ACS 5.1
acjarvis Mon, 10/12/2009 - 08:34
Thanks for the information. Do you have an approximate release date for ACS5.1?
kholst Mon, 10/12/2009 - 01:01
Under Shell Command Authorization mark [ciscowlc common] and [Custom attributes]
In Custum attributes apply following : role1=all
Regards Kim
