T.38 FAX Detection
Oct 9th, 2009
I have a problem with the recognition of T.38 faxes; my customer has migrated its telephony provider to T.38 and the fax Onramp does not work.
I think there is a problem in the script recognition, the fax detection. Fax detection script is updated to app_fax_detect.2.1.2.3.tcl.
Configuration is the following:
application
Service fax_detect flash: / / app_fax_detect.2.1.2.3.tcl
dial-peer voice 3 pots
Service fax_detect
incoming called-number 123456789
direct-inward-dial
port 0/0/0: 15
dial-peer voice 5 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 9989
information-type fax
session target mailto: [email protected]
Where is the error?
Thanks to all!
smahbub Thu, 10/15/2009 - 10:05
1. An incoming call is initially established as a voice call.
2. The gateways advertise capabilities in an SDP exchange during connection establishment.
3. If both gateways do not support T.38, fax pass-through is used for fax transmission. If both gateways do support T.38, they attempt to switch to T.38 upon fax tone detection. The existing audio channel is used for T.38 fax relay, and the existing connection port is reused to minimize delay. If failure occurs at some point during the switch to T.38, the call reverts to the original settings that it had as a voice call. If this failure occurs, a fallback to fax pass-through is not supported.
4. Upon completion of the fax image transfer, the connection remains established and reverts to a voice call using the previously designated codec, unless the CA instructs the gateway to do otherwise. If the CA has been configured to control fax relay, the CA instructs the gateway on processing the call with the fx: extension of the local connection option (LCO).
