ACS Authentication
Answered Question
Oct 9th, 2009
I am having an issue with ACS logging every single authentication that is made to devices in the Security log in Windows Eveny Viewer. Does anyone know how to shut this funtion off? I only want this log to report logon/logoff events for the server itself. Otherwise when i script out changes to devices the security log is bombarded with authentication events.
Correct Answer by Jatin Katyal about 7 years 4 months ago
HI MrCobb,
Do you have ACS installed on your Active directory? If yes then i don't think we can turn off this logging/
This happens when you have logon audit policy enabled on the server.
You may also check this:
http://www.windowsnetworking.com/kbase/WindowsTips/Windows2000/AdminTips/Security/EnableSecurityLogging.html
JK
Overall Rating: 0 (1 ratings)
