How to disable Tone on-Hold in CME
Oct 9th, 2009
I want to know is there any way to disable tone on-hold in CME.When user presses hold button when they are on conference every predetemined interval they are hearing 5 beep tones.In Callmanager there is an option to change it but in CME i have no idea.
Hythim Ali El Hadad Fri, 10/09/2009 - 11:16
  • Silver, 250 points or more
Hi harikrishnan,
Use a silent wav file as a MOH source for the group you need, so they will hea nothing
wish this be helpful
paolo bevilacqua Fri, 10/09/2009 - 11:18
  • Hall of Fame,
    Founding Member
I don't think this a good idea, first of all, you may want have a regular MoH instead of silence, as there are no MoH groups in CME, then MoH is not used for internal calls.
harisivaji Fri, 10/09/2009 - 11:45
What is the use of Hold-alert under ephone-dn is there any relation with this but i tried it out this as well but no luck.
paolo bevilacqua Fri, 10/09/2009 - 11:47
  • Hall of Fame,
    Founding Member
That is to alert you back you have call on hold, hence unrelated.
