10-09-2009 10:57 AM - edited 03-06-2019 08:04 AM
Neet to interconnect 2 datacenter (extend the Layer2) with 2 indipendent 1Gbps links (total available 2Gbps) and the requirements are:
- use 4 switches for HA (2 switches on both datacenters with each the 1Gbps link );
- transport between the 2 datacenter many ethernet 802.1q VLANs (layer 2 frame 1522 bytes);
- use all the band. available.
As solution is it possible to use/configure Multi-Chassis EtherChannel to aggregate the 2 links (or are available other feature to aggregate the 2 links)?
On which cisco platform is Multi-Chassis EtherChannel available ?
Any other solution (i know i can use spanning-tree and configure VLAN odd to the 1st link and VLAN even on the other) ?
Thanks to all.
Roberto Taccon
10-09-2009 11:11 AM
Hello Roberto,
I may be wrong but I think multi chassis etherchannel is a VSS feature that is on each side you should deploy two C6500 as a VSS.
Or you can use a stack of two C3750 on each side. They also support a bundle using links of different member switches.
using differentiated STP root bridges or STP per vlan costs should provide per vlan load sharing and can be a possible solution too.
Hope to help
Giuseppe
10-09-2009 12:18 PM
I post again the question:
*** request:
are:
- use all the band. available 2 Gbps.
*** planning
planning to do this bonding to a logically linked pair of switches that operate as a single virtual switch, using "MEC" or using etherchannel with stacking or â¦. (The theory is that if a switch in the MEC-pair fails, the bond/trunk link continues working through the other switch with degraded throughput.)
*** solutions and QUESTIONS :
**1st solution:
i use 2 stacked cisco switches (2 on the 1st DC and 2 on the other DC) and configure a Cross-Stack EtherChannel
Q.: ANY NEGATIVE CONSIDERATION (if i need to upgrade the IOs need to reload the entire stack simultaneously) ?
**2nd solution:
Q.: ON WHICH CISCO PLATFORM IS Multi-Chassis EtherChannel available ?
**3rd solution:
**4thsolution:
Q.: ANY OTHER SOLUTION ?
THANKS AGAIN.
10-09-2009 12:52 PM
Hello Roberto,
what is this?
a job interview, a design based exam scenario?
a real world job project?
however:
Q4:
port based EoMPLS provides extension over an MPLS network.
Hope to help
Giuseppe
10-10-2009 03:01 AM
Hi giuseppe,
thanks for the reply (it's a real job project).
May I ask you if the VSS feature will be available for other switch platform (45xx/37xx) ?
Roberto
10-10-2009 03:07 AM
Hello Roberto,
as far as I know the answer is negative:
VSS requires new specifically developed supervisors for C6500 and new 6708 or 6716 10GE linecards.
The new linecards have an ASIC on them that allow to encapsulate frames into VS protocol frame.
This chip is missing on C6704 that is not usable for the VSS link(s)
VSS exports control plane and data plane and a single supervisor controls both chassis with second supervisor in hot standby.
So it is not a viable option even with normal C6500 hardware it needs specific Hw and SW.
Hope to help
Giuseppe
