Unusual behavior on 2nd port of 2 port MC T3 card.
Oct 9th, 2009
I am having an odd problem. I have a 2 port MC-T2 card installed in a 7206VXR in slot 5. Port 5/0 is behaving as expected. We are bring up a new Channelizes DS3 on port 5/1 and I am getting behavior that generated the output below when I issue the "show controller T3 5/1" command. The controller shows DOWN while the T1 channels on the controller show UP/UP. any thoughts?
T3 5/1 is down. Hardware is 2CT3 single wide port adapter
CT3 H/W Version : 0.2.2, CT3 ROM Version : 1.0, CT3 F/W Version : 2.5.1
FREEDM version: 1, reset 0 resurrect 0
Applique type is Channelized T3
No alarms detected.
FEAC code received: No code is being received
Framing is M23, Line Code is B3ZS, Clock Source is Line
Rx-error throttling on T1's ENABLED
Rx throttle total 0, equipment customer loopback
Data in current interval (2 seconds elapsed):
0 Line Code Violations, 0 P-bit Coding Violation
0 C-bit Coding Violation, 0 P-bit Err Secs
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
0 Unavailable Secs, 0 Line Errored Secs
0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
T1 1 is up
timeslots: 1-24
FDL per AT&T 54016 spec.
No alarms detected.
Framing is ESF, Clock Source is Internal
Data in current interval (82 seconds elapsed):
0 Line Code Violations, 581 Path Code Violations
0 Slip Secs, 3 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
3 Errored Secs, 0 Bursty Err Secs, 3 Severely Err Secs
0 Unavail Secs, 0 Stuffed Secs
T1 2 is up
timeslots: 1-24
No alarms detected.
Data in current interval (83 seconds elapsed):
0 Slip Secs, 2 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
2 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs
Thanks..
paolo bevilacqua Fri, 10/09/2009 - 11:21
  • Hall of Fame,
    Founding Member
Why you blame the port?
Do you have evidence that the circuit is working on a different port ?
p-blake Fri, 10/09/2009 - 11:24
I am scheduling to move the circuit to another T3 port, that is currently working, to see if the behavior follows. Thanks for the input.
Giuseppe Larosa Fri, 10/09/2009 - 11:24
  • Hall of Fame,
    Founding Member
Hello Paul,
I see
this may be related to the fact second T3 is considered down
Hope to help
Giuseppe
paolo bevilacqua Fri, 10/09/2009 - 11:44
  • Hall of Fame,
    Founding Member
That in itself is normal, no loop code is being received.
All appears normal, but maybe telco has not completed their mux configuration.
