10-09-2009 11:20 AM - edited 03-14-2019 04:42 AM
Hi everyone,
I have a UCCX backup failed issue with one of our clients.
It's a UCCX 5.0(1)-SR02ES08-Build083. When i tried backup, the bar stopped at 5% and the error message is like this:
Unable to contact Call Manager. Please make sure that the Call Manager is running and connected to the network com.cisco.archive.impl.component.cluster.ClusterArchiveComponent; nested exception is: com.cisco.archive.ArchiveException: Fail to acquire bootstrap mutex; nested exception is: com.cisco.app.ApplicationException: can not acquire ClusterMutex; nested exception is: com.cisco.config.ConfigException: Get config record - error: catch cisco.config.ConfigException UnmarshalException; nested exception is: javax.xml.bind.UnmarshalException: Premature end of file. - with linked exception: [org.xml.sax.SAXParseException: Premature end of file.], refer to the MCVD logfiles for more details
Can anyone give me some idea?
James
10-09-2009 12:35 PM
I suggest you to use bars from call manager.
Farid
10-14-2009 09:17 AM
Thanks a lot buddy!
11-07-2010 11:39 PM
James,
did you find the solution for this problem (other then using BARS from CUCM)?
I have the same problem on version 5.0(2)_SR02ES11_Build110.
any ideas would be appreciated.
BR,
Jelena
11-08-2010 05:00 AM
This is a known issue. Workaround is to STOP the CSA and run the backup schedule.
11-08-2010 07:27 AM
Most common reason for the backup to fail is due to lot of RAW files in the folder "c:\program files\cisco\desktop_audio"
If there is more than 2 GB data in that folder I will suggest you to manually remove those files and see if the backup goes through. If its HA check both the servers
Anuj
11-12-2010 04:41 AM
The error message itself is fairly generic.
If its failed in the first 10% then it hasn't really passed the initial post checks.
Ideally you should look at the MIVR/MCVD to determine exact causes however a few things to check.
- Nic Binding
- Ensure there is no IPV6 configured on the UCCX
- Backup location is valid
- Host files are updated with UCCX node 1,2 and Call Managers
11-12-2010 04:54 AM
Hi James,
If backup is still failing after following Hoai's advice; please check to see if a lock has caused an issue with a previous backup. You can open appadmin and go to Tools > Backup and Restore > Status. If the backup has not run for sometime you most likely have a lock. You can do the following
1. Go to 'C:\program files\wfavvid\ClusterData\Default\' folder on CRS server;
2. Rename 'com.cisco.crs.cluster.config.LockConfig' folder to 'com.cisco.crs.cluster.config.LockConfig.bak';
3. Restart nodemanager
Then try a backup.
Joe
