CiscoSecure ACS v4.2
Oct 9th, 2009
Hello, just installedCiscoSecure ACS v4.2 appliance, I configured a test switch for TACACS access and notice I am getting a AUTHENTICATION FAILURE, i turned on debugging and it seemingly is a key issue. I checked the key and the issue persist. I think this may have something to do with internal Databse issue. What could possible be wrong with the key. The key on the switch is the same as on the ACS server, has anyone seen this issue.
capture from debug:
Oct 9 15:17:40.629 EDT: AAA: parse name=tty2 idb type=-1 tty=-1
Oct 9 15:17:40.629 EDT: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter
=0 port=2 channel=0
Oct 9 15:17:40.629 EDT: AAA/MEMORY: create_user (0x27BA528) user='NULL' ruser='
NULL' ds0=0 port='tty2' rem_addr='10.1.201.230' authen_type=ASCII service=LOGIN
priv=1 initial_task_id='0', vrf= (id=0)
Oct 9 15:17:40.629 EDT: AAA/AUTHEN/START (3776087011): port='tty2' list='' acti
on=LOGIN service=LOGIN
Oct 9 15:17:40.629 EDT: AAA/AUTHEN/START (3776087011): using "default" list
Oct 9 15:17:40.629 EDT: AAA/AUTHEN/START (3776087011): Method=tacacs+ (tacacs+)
Oct 9 15:17:40.629 EDT: TAC+: send AUTHEN/START packet ver=192 id=3776087011
Oct 9 15:17:40.629 EDT: TAC+: Using default tacacs server-group "tacacs+" list.
Oct 9 15:17:40.629 EDT: TAC+: Opening TCP/IP to 10.9.100.161/49 timeout=90
Oct 9 15:17:40.637 EDT: TAC+: Opened TCP/IP handle 0x2735E24 to 10.9.100.161/49
Oct 9 15:17:40.637 EDT: TAC+: 10.9.100.161 (3776087011) AUTHEN/START/LOGIN/ASCI
I queued
Oct 9 15:17:40.839 EDT: TAC+: (3776087011) AUTHEN/START/LOGIN/ASCII processed
Oct 9 15:17:40.839 EDT: TAC+: received bad AUTHEN packet: length = 6, expected
66610
Oct 9 15:17:40.839 EDT: TAC+: Invalid AUTHEN/START/LOGIN/ASCII packet (check ke
ys).
Oct 9 15:17:40.839 EDT: TAC+: Closing TCP/IP 0x2735E24 connection to 10.9.100.1
61/49
Oct 9 15:17:40.839 EDT: TAC+: Using default tacacs server-group "tacacs+" list.
Oct 9 15:17:40.839 EDT: AAA/AUTHEN (3776087011): status = ERROR
Oct 9 15:17:40.839 EDT: AAA/AUTHEN/START (3776087011): Method=LOCAL
Oct 9 15:17:40.839 EDT: AAA/AUTHEN (3776087011): status = GETUSER
Oct 9 15:17:50.972 EDT: AAA/AUTHEN/CONT (3776087011): continue_login (user='(un
def)')
Oct 9 15:17:50.972 EDT: AAA/AUTHEN (3776087011): status = GETUSER
Oct 9 15:17:50.972 EDT: AAA/AUTHEN/CONT (3776087011): Method=LOCAL
Oct 9 15:17:50.972 EDT: AAA/AUTHEN (3776087011): status = GETPASS
Oct 9 15:17:54.336 EDT: AAA/AUTHEN/CONT (3776087011): continue_login (user='jma
xwell')
Oct 9 15:17:54.336 EDT: AAA/AUTHEN (3776087011): status = GETPASS
Oct 9 15:17:54.336 EDT: AAA/AUTHEN/CONT (3776087011): Method=LOCAL
ALSO i ADDED THE COMMANDS BELOW:
aaa authentication login default group tacacs+ local
aaa authentication login MMC group tacacs+
aaa authentication login mmc group tacacs+
aaa authentication ppp default if-needed group tacacs+ local
aaa authorization network default group tacacs+ if-authenticated
tacacs-server host 10.9.100.161
tacacs-server timeout 90
no tacacs-server directed-request
tacacs-server key 7 01100F175804
Overall Rating: 5 (1 ratings)
Jatin Katyal Fri, 10/09/2009 - 11:45
If you have verified the shared secret key on the AAA/switch entry.
Go to Network Configuration > Select the Network Device Group (NDG) under which we have our switch registered.
Once we are in the Network Device Group in which we have our switch registered, take a look at the bottom of the page, you'll see an option which says "Edit Properties", clik on that botton,
Then make sure that we don't have anything configured for "Shared Secret", if we have something, remove it and make this field blank, and then press "Submit"
Then try to authenticate.
JK
Plz rate helpful posts.
janet.maxwell Thu, 10/15/2009 - 10:31
I did have a "Shared secret" configured which was not able to delete without a error. So what i did was delete the group and the AAA client then crecreated them, now it works. Thanks this worked
