What are dynamic ports?
Oct 9th, 2009
We're applying port security to our LAN switches and when I try to do it on certain switch ports I get a message saying:
"GigabitEthernet1/1 is a dynamic port. port-security parameters cannot be set."
So what is does that mean - a dynamic port? When I do a "show mac address-table gi 1/1" it shows the port type as dynamic. On some other ports on which I've been able to set port security on it shows them as being static. But we've never configured these ports one way or the other.
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 10/09/2009 - 13:01
  • Hall of Fame,
    Founding Member
Hello PAtrick,
you need
switchport mode access
default switchport mode is dynamic desirable (attempting to setup a trunk using DTP)
>>You cannot configure port security on dynamic ports. You must change the mode to access before you enable port security.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/port_sec.html#wp1148529
Hope to help
Giuseppe
