mls qos trust cos and device cisco-phone
Oct 9th, 2009
Question regarding these two features. Using the auto qos macro "auto qos voip cisco-phone" the switchport get configured with:
mls qos trust device cisco-phone
mls qos trust cos
but if you have conditional trust with the phone why are you just allowing all traffic marked with CoS? does that seem like it make the device trust non necessary?
thanks,
Overall Rating: 4.7 (4 ratings)
Edison Ortiz Fri, 10/09/2009 - 16:19
  • Hall of Fame,
    Founding Member
You need both commands. The first command instructs the switch to trust a cisco ip-phone. The second command instructs the switch to use 'cos' as the trust mode. If you don't enter the 2nd command, the trust mode in the port is untrusted and QoS markings will be reset to 0.
interface FastEthernet0/10
switchport mode dynamic desirable
Rack1SW4#sh mls qos interface f0/10
FastEthernet0/10
trust state: not trusted
trust mode: not trusted
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: cisco-phone
Rack1SW4#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Rack1SW4(config)#int f0/10
Rack1SW4(config-if)#mls qos trust cos
Rack1SW4(config-if)#end
FastEthernet0/10
trust mode: trust cos
COS override: dis
default COS: 0
Edison.
tomek0001 Mon, 10/12/2009 - 07:27
So basically cisco-phone command enables the device to be trusted and the trust cos defines what qos attribute (cos |dscp|ip-precedence) to trust from that device.
Edison Ortiz Mon, 10/12/2009 - 16:35
  • Hall of Fame,
    Founding Member
Correct
Edison.
Volodymyr Morskyy Mon, 01/11/2010 - 06:04
  • Bronze, 100 points or more
Not to create a new thread - I've understood
that "mls qos trust device cisco-phone" is a trust condition.But it is discussed(even in QoS course) as trust condition in a PC traffic point of view. What about phone signaling and RTP - are they trusted always(due to CDP)? Do I need to enter both commands to trust CoS and DSCP marking from Phone port...thank you in advance
prakadeesh Mon, 01/11/2010 - 06:23
Imho,
yes command "mls qos trust device cisco-phone" basically advices the switch that the Cisco Ip phone is doing the markings and just trust that for the queueing. So at the switch port we basically choose between cos or dscp to put in proper queue. RTP/Signalling traffic use their own dscp/cos that can be set by the IP phone. They are trusted  and queued either based on cos or dscp ( as per the switch port config) say RTP with dscp 46 is EF still trusted by siwtch port (if mls trusp dscp is chosen), signalling traffic may be say dscp 24/40(nortel phones) still trusted but queued depending on the dscp-queue map on the switch. stand corrected incase wrong.
hth
Volodymyr Morskyy Mon, 01/11/2010 - 06:32
Thanks for a quick answer.Still got no answer for my question)).
Lets take default settings on Catalyst and lets attach IP Phone and PC to this IP Phone.
Will be the phone signaling/media traffic given priority over PC traffic without
"mls qos trust device cisco-phone" and "mls qos trust cos/dscp" commands? Will be Phone signaling/media mrking discarded or kept?
prakadeesh Mon, 01/11/2010 - 06:51
without these two command all the traffic that comes to the port will be processed as per the default switchport config which is dont trust and the port will not be prioritising the voip traffic. I think a default cos value of 0 will be applied to the frames. dscp remarking may or may not take place depending on the switch config / dscp mutation map.
Volodymyr Morskyy Mon, 01/11/2010 - 06:58
Was writing exactly the same)) Just called myself from another IP Phone ans sniffed - all voice packets from another IPPhone were marked with DSCP=0x00 as well as Signalling to my IPPhone from CCM)/ So thank you for making me 100% sure) (Sorry can't vote - topic seems to be closed for voting after solving a trouble, but will try later from another browser)
