POTS failover dial-peers
Oct 9th, 2009
I have a PRI connected to the UC500 as primary and 4 POTS lines for failover in case the PRI goes down.
I have these two long distance dial-peers
dial-peer voice 61 pots
corlist outgoing call-domestic
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 71[2-9]..[2-9]......
port 0/1/1
prefix 1
no sip-register
dial-peer voice 2501 pots
description ** T1 PRI pots dial-peer **
preference 1
port 0/2/0:23
prefix 1
no sip-register
I wanted to test the failover by unplugging the PRI and making some long distance calls.  For some reason it kept wanting to use dial-peer 2501 (debug voip ccapi inout).  Only way to get it to dial out with dial-peer 61 was to remove dial-peer voice 2501.
Is there something else I need to have this failover to work?  Is unplugging the PRI not the correct way to test failover?
pro4ianyc Tue, 10/13/2009 - 09:57
Thanks.  Looks like the command I need is - dial-peer outbound status-check pots
What is the default setting? no dial-peer outbound status-check pots ?
Marcos Hernandez Tue, 10/13/2009 - 13:32
  • Blue, 1500 points or more
The default settings and corresponding behavior are described in the link I sent you.
Marcos
