static routing for http(s) traffic
Oct 9th, 2009
I have the following setup:
LAN1 with DHCP server 10.20.30.253 & Internet server as gateway for LAN with IP 10.20.30.254. Both are on the same subnet.
I have a remote site LAN2 which is getting DHCP from LAN1. That is working fine. However I need to route all http & https traffic from LAN2 to LAN1's .254 server.
Currently my router at LAN2 has gateway of last resort 0.0.0.0 0.0.0.0 LAN1
How can I make this router at LAN2 route all http & https only traffic route back to the http server (.254)?
TIA
paolo bevilacqua Fri, 10/09/2009 - 16:31
  • Hall of Fame,
    Founding Member
That is called PBR, if you search in the scrollbox you can get to the configuration guide or examples.
willemvwyk Thu, 10/15/2009 - 14:18
I am not sure if PBR will work as the WAN is on a /30 IP Range?
Another thought, can I build IP-IP tunnels between the sites and route these tunnels to the main site?
