Can I use wildcard masks in network command on 12.0 software
Answered Question
Oct 9th, 2009
hello. started studying for BSCI test. I have 3 routers 1 running 12.2 the other 2 running 12.0. the 2 12.0 routers will not accept wildcard masks with the network command. i am using the teare/paquet bsci book (3rd edt) example 3-4 on page 94. after router eigrp 109 (enter) network 10.1.0.0 0.0.255.255 i get invalid imput detected at the first
0. int s1 ip address is 10.1.1.1 255.255.0.0. and is in up and up state. tbere is no problem on the 12.2 router. this version limitation is not mentioned in the book and i have done several internet searches and not found any help for this. can someone please help.
Correct Answer by Richard Burts about 7 years 5 months ago
John
According to the command reference the wildcard mask was added for EIGRP in the 12.0T train. I assume that your routers are probably running 12.0 mainline (or perhaps very early 12.0T).
See this link for additional details:
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_eig2.html#wp1012165
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Sat, 10/10/2009 - 12:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
Rick
risk9high Sun, 10/11/2009 - 10:48
Thanks Rick
im running 12.0(27) Release Software(fc1)
also thanks for the link
