Why can't change EIGRP summary route administrative distance?
Answered Question
Oct 9th, 2009
Router A and B are running 12.3(22). I configured a EIGRP summary route on router A interface toward B with various administrative distance values. But in router B routing table, the summary route is alway EIGRP route with distance 90.
Router A:
interface Ethernet 0/0
ip summary-address eigrp 1 192.168.0.0 255.255.0.0
Router B routing table:
D 192.168.0.0/16 [90/2684416] via 172.20.1.1, 00:00:30, Ethernet0/0
Isn't the summary router default to administrative distance of 5?
Thanks a lot
Correct Answer by Lucien Avramov about 7 years 4 months ago
R2(config-if)#do sh ip route 192.168.0.0
Routing entry for 192.168.0.0/16, supernet
Known via "eigrp 1", distance 5, metric 28160, type internal
Redistributing via eigrp 1
Routing Descriptor Blocks:
* directly connected, via Null0
Route metric is 28160, traffic share count is 1
Total delay is 100 microseconds, minimum bandwidth is 100000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 0
Thats the type of output you will see.
Great I guess we can mark this post resolved.
Overall Rating: 5 (3 ratings)
Jerry Ye Fri, 10/09/2009 - 18:39
Distance value is locally significant.
When you configured summary address in router A, the admin distance of the summary route is 5. When router A send the route to router B, router B will see it as a native EIGRP route and assign it with a admin distance value of 90.
HTH,
jerry
Lucien Avramov Fri, 10/09/2009 - 18:42
That changes the admin distance to 5 on router A.
Do a show ip route 192.168.0.0 on router A and you will see a route to null0 with an admin distance of 5.
gwhuang5398 Fri, 10/09/2009 - 19:03
Thanks a lot. Somehow on router A routing table, it only shows the summary route to Null0, with no distance value attached.
I misunderstood that router B would give the received summary route a distance value 5. Now it's clear.
Thanks again
Correct Answer
Lucien Avramov Fri, 10/09/2009 - 19:16
