best practice for snmp-server views?
Answered Question
Oct 9th, 2009
As a best practice when creating an snmp-server view, should these views be excluded?
snmp-server view cutdown snmpUsmMIB excluded
snmp-server view cutdown snmpVacmMIB excluded
snmp-server view cutdown snmpCommunityMIB excluded
Correct Answer by Joe Clarke about 7 years 3 months ago
No, it's not included automatically. You would need to include these branches in your custom view.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 10/09/2009 - 19:08
Absolutely. With these branches included, one could learn the SNMP credentials of the device. The default v1default view is defined as:
v1default iso - included permanent active
v1default internet.6.3.15 - excluded permanent active
v1default internet.6.3.16 - excluded permanent active
v1default internet.6.3.18 - excluded permanent active
v1default ciscoMgmt.394 - excluded permanent active
v1default ciscoMgmt.395 - excluded permanent active
v1default ciscoMgmt.399 - excluded permanent active
v1default ciscoMgmt.400 - excluded permanent active
Which essentially excludes all of the branches which could result in security compromise.
david.fernandes... Fri, 10/09/2009 - 19:21
Thanks. Is the v1default view included automatically when I create a new view, or do I need to add these in?
Correct Answer
Joe Clarke Fri, 10/09/2009 - 19:25
