Basic Router configuration
Oct 9th, 2009
I need help on basic configuration for two routers to talk with two different networks. Please email me a basic configuration that I can use. I have two Cisco 2801.Please advise.
Thanks, June
jiaowenbin Fri, 10/09/2009 - 21:49
It's too easy , C2801-1 as A ;C2801-2 as B
10.0.0.0/24-Lan1-fa0/0-A-fa0/1-fa0/1-B-fa0/0-Lan2-192.168.0.0/24
A:
hostname A
interface fa0/0
ip add 10.0.0.254 255.255.255.0
exit
interface fa0/1
ip add 172.16.1.1 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 172.16.1.2 255.255.255.0
B
hostname B
interface fa0/0
ip add 192.168.0.254 255.255.255.0
exit
interface fa0/1
ip add 172.16.1.2 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 172.16.1.1
its ok
june_encarnacion Sat, 10/10/2009 - 16:31
Hello...I made a mistake on the router model...is should be 2811.Will the configuration you gave me work?
Please advise.
June
