10-09-2009 11:50 PM
I got an error when connecting VPN, detailed messages are attached. I am using administrator to log on. The issue is there after I run a virus clean activity. Any help is appreciated.
Cisco Systems VPN Client Version 4.6.04.0043
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
1 15:16:21.625 10/10/09 Sev=Warning/2 CVPND/0xE3400003
Function CreateFile failed with an error code of 0x00000002(DRVIFACE:718)
2 15:16:22.546 10/10/09 Sev=Warning/2 CVPND/0xE3400003
3 15:16:23.046 10/10/09 Sev=Warning/2 CVPND/0xE3400003
4 15:16:23.546 10/10/09 Sev=Warning/2 CVPND/0xE3400003
5 15:16:24.046 10/10/09 Sev=Warning/2 CVPND/0xE3400003
6 15:16:24.546 10/10/09 Sev=Warning/2 CVPND/0xE3400003
7 15:16:25.046 10/10/09 Sev=Warning/2 CVPND/0xE3400003
8 15:16:25.546 10/10/09 Sev=Warning/2 CVPND/0xE3400003
9 15:16:26.046 10/10/09 Sev=Warning/2 CVPND/0xE3400003
10 15:16:26.546 10/10/09 Sev=Warning/2 CVPND/0xE3400003
10-10-2009 05:31 AM
Is your anti-virus software quarantining or deleting a file from the Cisco Systems folder?
10-10-2009 05:34 AM
Does the error go away if you re-install or after you connect? I would recommend upgrading to the latest client. Looks like a bug.
