Paolo Bevilacqua Sat, 10/10/2009 - 04:10
There is no firmware for pvdm to upgrade.
To download IOS updates, you have to buy a support contract first.
Sushil Kumar Katre Sat, 10/10/2009 - 22:32
Hassan,
Are you using Digital Modem PVDM Module? If yes -
Q. How can I get the firmware version on the modems?
A. The modem firmware is bundled with Cisco IOS Software; you can find the version using the following command-line interface (CLI): "show modem version". You can also upgrade the firmware using the "modem firmware slot" CLI.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/qa_c67_541965_ps5855_Products_Q_and_A_Item.html
If you are using DSP PVDM modules, then no.
-> Sushil
Nicholas Matthews Tue, 10/13/2009 - 05:56
Hi Hassan,
It is possible to upgrade the DSPware for PVDMs. However, this is a last-resort tactic we use in TAC and is absolutely not intended for "let's see if it solves my problem" troubleshooting. It's likely you had a TAC case and they upgraded your DSP firmware, but this is NOT something you want to do on your own.
See this document for details:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080a7af82.shtml
-nick
