MPLS EIGRP
Answered Question
Oct 10th, 2009
dear all,
pls suggest for following points
sorry for attching jpg file because it difficult to draw topology in notepad
issue
i am getting all the vpnv4 routes on all PEs, i am able to ping vrf IP of another PE but i am not able to ping client end MPLS ip from another PE but its pinging from local PE, although routes are not learning at CE
pls find attached config notepads
Correct Answer by Harold Ritter about 7 years 5 months ago
Sourabh,
You are not redistributing BGP into eigrp on the PE routers. That is why your CEs are not receiving the remote routes. you need to add something like this on all PEs:
router eigrp 2101
address-family ipv4 vrf MGL
redistribute bgp 10 metric 10000 1000 255 1 1500
Overall Rating: 5 (1 ratings)
Correct Answer
Harold Ritter Sat, 10/10/2009 - 04:59
  • Cisco Employee,
Sourabh,
router eigrp 2101
