PIX Login issue
Oct 10th, 2009
Hello Champs,
I am using PIX-506E version 6.3(5)
In order to do a scheduled config download, my script is hard coded to login
with a user name and password and execute the show running command. However, since i have enable password configured, I am unable to exectue the show running from the user mode.
My question is I can create a different username & password, but the criteria is that it should go to the priviledge mode directly. Since my script is hard coded, i am unable to modify it. Below is the AAA commands for your reference. Any help is highly appreciated. Thanks in advance
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
Manoj
Jatin Katyal Tue, 10/13/2009 - 04:18
  • Cisco Employee,
Hi Manoj,
ASA/PIX/FWSM does not support AAA Exec
Authorization functionality yet, so it cannot be configured with TACACS or
RADIUS to jump directly to privilege exec mode. you need to go through with enable authentication mode.
username: xxxx
password:xxxx
>enable
password:
JK
Plz rate helpful posts-
