hub and spoke vpn
Oct 10th, 2009
hi techies,
i need to configure hub and spoke between 4 sites ..i have static ip on 1 site ,so that site i am using as hub and other sites are having dynamic ip.and i need to intercommunicate all sites each other through vpn thats why i am using this method.so plz provide me the config ,how to configure hub and spoke sites.
if you have any other method to intercommunicate all sites through vpn plz provide me.
thanks
zeuscyril Sun, 10/11/2009 - 21:48
hi jor,
thank you for ur links.
i need for router to router hub and spoke
example .if u have any example can send to me plz
thanks
JORGE RODRIGUEZ Mon, 10/12/2009 - 06:30
  • Green, 3000 points or more
Cyril, sorry I should have asked ..
Go to this link
https://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
Mid page down see section under IPSec on Router to Router
U shoudl find what you need to build your ipsec tunnels .
I would first start referencing Configuring Router-to-Router Dynamic-to-Static IPSec with NAT since you have static at the hub and spokes are dynamic, then reference Router-to-Router Hub and Spoke with Communication Between the Spokes section.
