How can we monitor the light levels of a 10Gbps tranceiver
Oct 10th, 2009
10Gbps link is bouncing. How can I monitor the light levels of a 10Gbps tranceiver?
OSR#sho int te 8/3 transceiver
Transceiver monitoring is disabled for all interfaces.
Card Reset: Not Applicable
Card Re-seated: Not Applicable
show tech attached: Not Applicable
Messages / Logs attached: Not Applicable
The device is a Cisco 7609 running 12.2(33)SRB4.
Mayamba
Giuseppe Larosa Sun, 10/11/2009 - 03:41
  • Hall of Fame,
    Founding Member
Hello Mayamba,
you may be able to use Digital Optical Monitoring for this.
check your transceiver in this list
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html
and see this thread of some mounths ago
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cd3f355/3#selected_message
you probably need to enable in global config monitoring for all transceivers types.
Edit:
you can use search option on topr right corner with search string =DOM to find the referred thread
Edit2:
another feature that can be useful is
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/intrface.html#wp1066783
see section
Configuring the Port Debounce Timer
Hope to help
Giuseppe
