Changing the default behavior of CUE 7 after leaving a message
Oct 10th, 2009
As you know the default behavior of CUE for leaving a message is:
1. Caller leaves message
2. Caller next presses # for more options after leaving a message
3. Machine then asks "If you want to send your message normal priority press 1"
4. Machine then asks "If you want to send your message urgent priority press 2"
after pressing one or two the call will transfer to operator.
I do not need the call to be transferred to the operator. Is there any way to do this??
