tx-power questions
Oct 11th, 2009
attached is the output of
"show country supported tx-power" command in WLC6.0.
From there you can see the max tx-power for each country. From the output, u can see that most of the tx power is 20dBm for b/g. However, in the CCO doc "channels and maximum power settings for LighWeight AP" document, it shows 17 for most of the countries.
WHy is there a difference? Am i missing anything?
Eng Wee
jeromehenry_2 Mon, 10/12/2009 - 07:55
  • Silver, 250 points or more
Which cco document are you referring to?
Local regulations usually imply both max transmit power at the AP level, and EIRP (Effective Isotropic Radiated Power). EIRP combines AP transmit power, (cable loss) and antenna gain, and this gives you the max power allowed at your AP antenna level. So depending on if the AP has an external antenna or not, the AP max transmit power may vary to take the AP antenna gain into account...
So make sure that you read a document that matches the AP type...
hope it helps
Jerome
dlawson001 Tue, 10/13/2009 - 06:24
Yes, different countries have different power level limits. The FCC regulates the US's and our max DBM is 36 (30dbm power with 6dmb gain). You can adjust the power as long as you adjust the gain in a 3:1 ratio. Other countries go by a 1:1 ratio.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
