How to enable SSH nad nating at the same time
Oct 11th, 2009
Dears,
The problem is i have a static ip on router interface and it is configured for pating.
But i can't ssh to the public ip address unless i remove the IP nat outside on the wan interface.
Is there a solution to this issue?
paolo bevilacqua Sun, 10/11/2009 - 03:09
  • Hall of Fame,
    Founding Member
Please check the ACL used in "ip nat inside source" command. If it contains "any", that is the cause.
