TFTP IOS file transfer fails
Reza Sharifi Sun, 10/11/2009 - 11:11
  • Cisco Designated VIP,
    2017 LAN
What TFTP server are you using?
some TFTP servers crash if the file is more then 16Mb.
I use pumpkin TFTP server and it is pretty good.
Reza
I had the same problem and it was with the software as the other post stated, can you look at the log on the server side. I always use a source command for TFTP so I can look at FWS with a dump and I know for sure what IP it is sourcing from. But I would say to check the software and try FTP and see what you get.
Leo Laohoo Sun, 10/11/2009 - 18:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Means that the file is not found in the default folder of the TFTP server.
Richard Burts Mon, 10/12/2009 - 05:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Leo
The original post says that the error is "receive this messsage in the middle of the transfer". If the issue is that the file is not in the default folder how does any transfer take place?
Rick
Leo Laohoo Mon, 10/12/2009 - 17:35
  • Hall of Fame,
    2017 LAN, Wireless
Good point Rob. I missed that. :(
I guess the only way, since he's copying the .bin file anyway, is to TFTP from an existing 3750 with this IOS.
Lucien Avramov Mon, 10/12/2009 - 17:36
  • Red, 2250 points or more
You may be running out of flash space on the switch for the image to be transfered. Check the flash: "dir flash:"
