Line clock settings 2Mb leased line
Answered Question
Oct 11th, 2009
Believe it or not but a providor in Norway delivers not a clock signal in a point to point 2 Mb leased line.
What is now the best way to configure the clock setting on both routers ?
Normaly the config is; clock source internal But must you set that on both sides or only on one? And how do know that than both clocks are in sync ?
Correct Answer by Giuseppe Larosa about 7 years 7 months ago
Hello Rene,
use clock source internal on one side and clock source line on the other side.
This should be fine.
there is no direct way to see this you need to consider interface statistics over time if some type of interface errors don't increment over time clocking should be correct.
see
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1915.html
for T1/E1
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Sun, 10/11/2009 - 22:09
  • Hall of Fame,
    Founding Member
Hello Rene,
see
for T1/E1
Hope to help
Giuseppe
r.vanschendel Sun, 10/11/2009 - 22:16
Hi Giuseppe
Thanks for your time and the answer. It is what I expected, but now I am sure.
